Issue with AVG Antivirus slowing down my Pc
Hello hamza,
We understand that you suspect that AVG might be slowing your PC.
We'll certainly check and help you out.
Could you please let us know when you started facing this issue?
If you think AVG Antivirus is slowing down your PC, you can try these steps:
Check for updates: Make sure your AVG program is up to date.
Please check this article for Updating AVG: | AVG (https://support.avg.com/SupportArticleView?l=en&urlName=update-avg-antivirus&q=update)
Disable AVG: You can disable AVG Internet Security or temporarily disable AVG AntiVirus protection
To disable:
Right-click the AVG icon in the System Tray. This is located in the lower-right corner of the desktop. …
Click Temporarily disable AVG protection.
Choose how long you want the protection to be disabled and whether to disable the firewall as well.
Click OK.
Check if you see any improvement in the speed.
Check for other antivirus software: See if there's any other antivirus software installed on your computer, as it can cause conflict.
Alternatively, we suggest you to repair AVG and check again.
To repair AVG Antivirus on Windows, you can try the following steps:
Make sure no other applications are running
Press the Windows key and the X key at the same time
Select Programs and Features from the menu
Right-click AVG Internet Security or AVG AntiVirus FREE and select Uninstall
Click Yes if prompted by the User Account Control dialog
Click Repair when the AVG Setup window appears
Wait for the setup to repair AVG AntiVirus
Click Restart computer to reboot the PC and complete the repair
If a restart is not needed, click Done
Please do try these steps and check if you still face any issues.
Hi everyone, I have been using AVG Antivirus on my Window 10 Pc for a while now, and i have noticed that my system has been  running slower due to which the speed of my site has also become slow. Could this be related to AVG? and if so, are there any settings or features i can adjust to improve performance without compromising security.
Thanks in advanced for you help!
Hello hamza,
To disable:
Click OK.
