Issue with AVG Zen installation, error: 0xA001F90D
Hi Benny,
I understand this must be upsetting. I will help you to fix it.
To resolve the issue please follow the steps provided in this article : http://support.avg.com/SupportArticleView?urlname=How-to-troubleshoot-issues-after-upgrade-to-the-latest-AVG-antivirus-product
Note : Please run the AVG Clear first and then the AVG Remover
Once uninstalled, please reinstall the AVG TuneUp-Unlimited from http://support.avg.com/SupportArticleView?urlname=Download-and-install-AVG-Performance
Hi Benny,
Hello Benny,
I'm sorry to hear that you're still experiencing issues with AVG TuneUp - Unlimited installation. I have sent you an email, please follow the email instruction to connect with us remotely. We will check with the error message and previous AVG traces and we will help you to fix the issue in no time.
Best regards,
Hello,
I've bought the TuneUp Unlimited Package, bute unfortunatelly the installation of ZEN doesn't work. After the input of my datas the installation allways shows me the following error code:0xA001F90D. You can see it here: https://gyazo.com/38a3f0a6a96d90ad1d9a6bb3902830f3.
I'm using Windows 10, Version 10.0.16299 Build 16299.
Hope the get help soon.
Hello,
thx for answering so soon. I have run the AVG Clear, then the Remover as described in the post, then I've tried to installed the AVG TuneUp Version of the post. Same error as before… please see:https://gyazo.com/aa80f155a9e12746ea79aa52494ec614.
Remover hadn't found something, I've run it anyway, but problem is still here.
