License key problems
Dear sir,
Many thanks for your quick response. I have performed all the actions you told me to do according to your response. Everything works fine now. Many thanks again.
Kind regards,
Alje Bakker
Hello Alje,
This is a known issue, a popup from AVG will come up repeatedly saying as "AVG LICENSE ERROR" and it will ask for license number.
This popup occurs for all trial, paid and free version.
It is a bug and to fix this we have to completely reinstall AVG free using our AVG remover tool.
1) To download the AVG remover tool please click on this link:
3) Your computer will be restarted automatically. After the restart, AVG Remover will finish the uninstallation.
Dear sir,
I am using AVG Antivirus Free 2016. It occured lately a few times that I got the message from the user interface to reenter the license key because I had some problems with my PC (would not startup). Because I use the free version I can't see the complete key in the program; the last three or four characters are missing (on purpose, I noticed). However to get my AVG Antivirus Free working again I had to remove the old installation and reinstall it again. This is very annoying and time consuming. Is there another solution for this issue?
Kind regards,
Alje Bakker
Dear sir,
Kind regards,
Alje Bakker
Hello Alje,
Hello Alje,
We are glad to know that the issue has been resolved. Thank you so much for letting us know. We appreciate your valuable efforts to fix the issue. Please feel free to contact us again for any assistance. Thank you.
