Hi Shaun,
We'll be glad to help with your concern.
I suggest you refer the below article to configure the AVG Firewall settings and check if you're able to connect.
https://support.avg.com/SupportArticleView?urlname=AVG-Antivirus-Enhanced-Firewall-System-Rules
Thanks in advance.
I am unable to Connect to the MSDisplay Adapter to Mirror/Connect an extended Display while AVG Firewall is running. When I disable it I am able to connect and project the screen out using Windows.
How do I set an exception so I am able to connect to an external display wirelessly without disabling the firewall?
Hi Shaun,
Thanks in advance.
