Onedrive not syncing bec java script issue
Hello ronald,
Thank you for contacting AVG support community.
I apologize for the trouble caused.
Could you please confirm on how long you are facing this issue?
Please disable AVG Internet security using the below article and check if everything works fine.
| AVG (https://support.avg.com/SupportArticleView?l=en&urlname=Disable-AVG-Antivirus)
We will certainly help you out.
Onedrive not syncing bec java script issue even though AVG setting allows. I get the pop-up on each log on.
Hello ronald,
