Outbound emails not going out
Hi
My Outlook365 on windows 10 is not sending emails out. Receiving no problem.
Hi Siva,
If you suspect AVG is causing the issue, please disable AVG protection temporarily & check if you're able to send emails.
Meanwhile, you can try sending emails via browsers.
