PC Tuneup and 1 Click maintenance
Thank you John. I have sent a log download to AVG so we will see what happens.
Browser cleaning currently doesn't work with latest version of Chrome.
Hi Ian,
I would like to inform you that this issue should be fixed in current BETA build (http://share.avg.com/steam/PSP/TuneUp/avg_tuh_stf_all_2015_331_beta.exe).
When I run AVG-1 Click maintenance the program begins to run and gets into 'Clean up browser', green bar approx 80% across, the program then 'disappears' and does not complete the clean up. I have tried it through PC Tune up and the same occurs. The product is uptodate as far as fixes are concerned. Windows 8 automatic updates is on.
Hi Ian,
