PC Tuneup "Fade tooltips in and out" keep reactivating
Hello Curtis,
Thank you for contacting us. Is "Fade tooltips in and out" an application? If so, PC Tuneup may recommend you to disable some rarely used programs to reduce load on your CPU. They remain disabled in the background until you use them next time. So you may see the same program being recommended to disable repeatedly.
If the pop up you are receiving is something else from the above scenario, please share a screenshot ( http://avgclick.me/getscreenshot ) of it to assist you better. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Under PC Tuneup about once a month I get the recommendation to deactivate Fade tooltips in and out.  Why does it keep reactivating?
Hello Curtis,
