PC Tuneup update problem
Hi Rich,
I noticed that you contacted support after creating this question. What is current status, were you able to solve it or do you still need our assistance?
My PC Tuneup tells me there is an update.  When I go to get it, it says I have no internet connection.  I removed my old 2013 version and installed the 2015 version.  Same problem.  I switched from WiFi to a direct LAN connection.  Same problem.  Multiple reboots.  Same problem.  Turned off AVG firewall protection. Same problem.  I have a very firm 16 Mbps connection and have been able to do everything on the internet except run this one program.  What's wrong?
Thanks,
Rich
Hi Rich,
