Printer and scanner will not work since installing. Tried to end subscription and get a refund but did not work
Hi Sharon,
We are really sorry to know that the printer and scanner is not working. We'll certainly check and help you out.I am sorry to know that you have decided to get a refund. Please allow us an opportunity, we will check this for you.
Open AVG AntiVirus and click the Web & Email tile on the main application.
Click Settings (the gear icon) in the top-right corner of the screen.
Click Basic protection ▸ Enhanced Firewall in the left panel.
Click View Firewall rules.
Select the Basic rules tab.
Here check the first option mentioning printer sharing, enabled or not.
Ensure you have it enabled under Private.
Also, check that you are connected in the Trusted network.
Check if you can use the printer and scanner now.
Hi Sharon,
