Hello Kodjoe,
I apologize for the inconvenience caused. To resolve any issues with AVG interface, please repair AVG once. To repair your AVG please follow these instructions:
Go to Start -> Control Panel.
Select AVG Antivirus in the list of programs.
Select Repair.
Restart your computer.
hi, I installed a free version of AVG and all is ok with it. My problem is simple, i can't see my interface when i click on AVG but i can confirm that i'm using the last version of it, because i wanted to install it again and i can't.
Hope you can help me, thank you
Hello Kodjoe,
Select Repair.
