Jon,
Sorry for the trouble, let us know whether your AVG Antivirus is up to date. Could you share the screenshot https://support.avg.com/SupportArticleView?l=en&urlName=How-to-create-a-screenshot&supportType=home of that error message you have received and version of AVG Antivirus you have installed?
Also, try to update your AVG Antivirus and then try downloading your windows update. We are here if you need further assistance.
Hi all,
I seem to be having problems getting the update for the Meltdown ''problem'' from Microsoft, after reading that it could be linked to my AVG antivirus I found that the registry entry required was not there, after following some advice on the forum I repaired and rebooted, now the correct registry entry is there but its still not updating, any ideas? could it be connected to something else on the system?
Many thanks in advance
Jon,
Jon, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions. Also for info this article has now been produced by AVG Technologies (https://support.avg.com/SupportArticleView?l=en&urlName=AVG-Meltdown-Spectre-vulnerabilities).
