Hello Quincy,
We regret for the inconvenience caused. Please be informed that AVG program will not conflict with the Pdf files, however we would request you to run AVG remover tool to completely remove AVG and then re install it.
Hello Quincy,
Since I renewed my AVG subscription a few weeks ago and down loaded the latest version of AVG Zen to a Windows 7 laptop, I have not been able to print PDF's. Printing from other files present no problem. But, when I print PDF's, I get an error message that says "This document could not be printed", and when I click "ok" a second message says "There were no pages selected to print". I'm also having a problem completing "fillable" PDF because it won't allow me to enter the fillable field. I have uninstalled and reinstalled the PFD viewer without success. I have also disabled AVG Protection to print PDF's without success. Suggestions would be appreciated.
If you are facing the issues even after reinstalling the program it is recommended to contact the PDF support so that they could analyze the issue for you.
