Angelidis,
We appreciate your efforts in trying to fix the issue, we apologize for the difficulties. We can resolve this issue by uninstall and reinstall AVG in safe mode.
Please reboot your device http://avgclick.me/rebootintosafemode in safe mode, click on this link to run Reset Access tool: http://files-download.avg.com/filedir/util/AVG_ResetAccess.exe and refer this article to uninstall http://avgclick.me/UninstallAVGAV your AVG program.
Kindly download your AVG remover and run it, then go to C: -> AVG Remover -> Bin ->pctremover.exe and avgfmwremover.exe (do not restart your device if prompted), then run avgremover.exe (it will automatically reboot your device).
I had the AVG free version. I couldn't do an update and got a general error code: 0x0643 followed by 0x0070643. I uninstalled the program using AVG remover. I have attempted to install the free AVG version but keep getting the same error and I am now in a loop - uninstall, install, error…
I have read the community posts, and this issue seems to pop up quite often…but not on re-installation, so not quite sure what to do now.
Any help would be greatly appreciated as I have no antivirus protect on at the moment.
Many thanks.
Angelidis,
