Hello all, I know that working from home has it's advantages. I use splashtop enterprise to connect to my work computer. Both computers are high-end workstations, 32g of memory, dual displays, fast processors running win 10 64 pro. However, during the day splashtop is constantly slowing down to a point that it is just crazy. I use Autodesk Civil 3D 2021, Outlook, Teams etc. Anybody else found a way to make using 2 anti-virus programs work better. I made a exception in my AVG Bus. Anti-virus for Splashtop but I'm not convinced that is the best solution to a faster experience and lag time to get my job done.
Hello Mike,
If you have slowdown issue on your PC, you need to have AVG Tuneup program installed on the PC. Also, you need to optimize the PC using Tuneup regularly. This will help you to remove junk and cache files and make sure your system runs at good speed.
Please confirm do you have AVG Tuneup installed on the PC? If yes, can you please try to run maintenance scan and check it. Keep us updated.
