Remote control applet
Hello Adrián,
You can find answer to your question together with your another post here https://support.avg.com/answers?id=906b0000000bnGl .Please try keep whole conversation in one question/thread to speed up resolution. Thank you.
In sight that does not work well AVG Tuneup 2016 in my computer with Windows xp I go to uninstall. The problem is that before I did a few consultations and the remote control applet disburdened, which never finishes of establishing itself and though it extinguishes the computer on having returned to ignite it it continues being tried to
Adrián, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions. Please refrain from carrying out multiple postings on the same subject! You won't obtain an answer to your query any faster!.
Hello Adrián,
