Right click scan blank page
Hi Chris,
Thank you for contacting AVG Community Forum. I see you are facing issues with I am sorry for the inconvenience. To troubleshoot this issue, I would recommend you to uninstall and reinstall AVG Internet Security. Refer the article for the instructions:
Uninstall AVG Internet Security (https://support.avg.com/SupportArticleView?l=en&urlName=Uninstall-AVG-software-Clear-Remover&supportType=home)
Reinstall AVG Internet Security (https://support.avg.com/SupportArticleView?l=en&urlname=install-avg-internet-security&retUrl=support_Internet_Security)
I hope this helps. Thanks and Keep us updated.
before playing games i normally right click .exe file and scan the game or map files as a habit, but recently i reinstalled windows and had to reinstall everything and been 2 weeks since that happened but my problem is i redownloaded everything i use to use and play and when i play games i always right click and scan but recently when i do that AVG internet security pops up as normally and start scanning but it is just a blank page no scanning indications or buttons or what ever there normally is, i repaired it and it got fixed so i closed the avg internet security browser so to test it to see if it helped out i scanned and the problem started accuring again blank page with nothing on in, what is ee is logo with name on top left and top right top right messages and menu and minimize and exit/close, rest of the screen just black/dark screen what ever the background is on AVG internet security is,
Hi Chris,
We're sorry to hear that the issue persists, Chris.
To further investigate this issue and help you resolve it, we've sent you an email with detailed instructions to contact our additional support.
Please check your inbox/spam folders to find the email and use it to contact them at your convenient time.
Thank you for writing us back, Chris.
Our concern team already sent an email to help you with the issue please reconnect with us using the email for further help.
everything have been explained and did get informations relayed what the actual problem is and first person checks what is running and what programs im using and saw i used diffirent virus program and basicly trying force shut that down kept persisting turning it down now i understand you try be friendly and have it off so the pc is more optimal what not but when i never said anything about those need to be turned off the only permission i gave was you fix your avg browser for scanning not showing the informations when right click scanning option, when avg browser is manually opened it shows the scanning and information but when scanning it didnt instead of actually checking avg settings or any other relations to avg program he focus something else which has nothing to do with the issue, your reply probably gonna be "there might be incosistance issues" kept insisting to turn off malwarebytes i never had those problems for 10+ years how long avg and malwarebytes ever was made, anyway dont like the way they handled it thanks for trying but no thanks for the help i continue with how it is
