Scan Folder via Explorer context window (right click)
Hello Derpy,
This isn’t expected behavior. We’ll work through fixing this together. In this case, I request you to repair AVG Protection (http://support.avg.com/SupportArticleView?urlname=How-to-repair-AVG), update (open AVG Antivirus free > menu > settings > update) it one more time and reboot your computer once. After reboot, please check if the context menu is working fine.
Best regards,
Hi!
Newbie question.
Is it possible to configure AVG Antivirus free, so i can right click on a file/folder
and trigger a virus scan, via the context menu over them?
My previous (abandoned) Virus Software could do that, and it was really helpful.
I humbly accept my beating, should this be an obvious RTFM.
Did some searches over the forums thought and dint find anything.
thanks
Klaus
Derpy,
Thank you updating the status and for the valuable feedback.
You can submit this as a feedback to our developers directly by filling the form - AVG > Menu > About > Submit Feedback.
Derpy,
Thank you for reaching us. Yes, AVG Antivirus Free have the option to scan folders through the context menu.
Hello Derpy,
Best regards,
