Hello Connie,
We regret to hear about the inconvenience caused. We would like to inform you that the issue is caused due to a recent windows update KB3194496. Please go to control panel to uninstall this update and then disable automatic windows updates to avoid getting this patch again. Once you uninstall this update, you must be able to scan your PC using AVG.
Please, feel free to let us know if you require any further assistance. Thank you.
I put the AVG scanner on this evening, as usual. Right away I received several threats,
then got a message form Windows saying it had to shut down right away and reboot. This happened about 3 times. There was a message explaining the problem , but I did not have time to write it down. Has this happened to anyone else? I have never had this happen before, I have never had any problem with AVG before either.
Hello Connie,
