Sky Go Connection
I have the AVG VPN connected to a UK based streaming server and I am in the UK, but when I open Sky Go on my PC I get the message that Sky Go isn't available outside of the UK or ROI Code 1415.
This happens on both my PC and my laptop.
Any ideas how to fix please?
Hello Richard,
We will check and help you with this issue.
Have you tried to turn off AVG Secure VPN program and then check if it helps?
You can also try to change AVG Secure VPN server location to Gotham City or Wonderland and then check if it helps.
When I disconnect the VPN sky Go works ok.  This is the case on both my desktop PC and laptop.  I have tried changing server to Wonderland and I have the issue of out of region message as above.
Richard
Hello Richard,
