My AVG internet security has always scanned for browser threats, viruses and advanced issues. On 15/2/2022 I changed to AVG Ultimate. Since then he smart scan no longer scans for advanced issues. Is this a different version of internet security without advanced issue scanning, or do I have a problem that you can solve? Thanks. From Jeffrey Sadler. jeflyn@telkomsa.net
Hello Jeffrey,
Thank you for reaching AVG Support Community.
I'm glad to clarify this to you.
AVG Ultimate (Multi-Device) is a bundle of 04 AVG products as follows,AVG Internet Security, AVG TuneUp, AVG Secure VPN and AVG AntiTrack.
You can install it on various devices like Windows Pc's, Mac Pc's, Android and Ios mobiles. You can totally use your AVG Ultimate subscriptions up to 10 devices.
To know more about AVG Ultimate Subscription, refer to this article.
The AVG Internet Security is same as you used before.
By default, the Sensitive Data Shield (advanced issues scan), is turned on and available to scan and protects your sensitive documents against unauthorized access and malware. Sensitive files contain your personal information that, if revealed, can compromise your privacy and identity. Sensitive Data Shield secures your private data by controlling which applications and users have access to your files.
To access it, please follow the below steps,
- Open the AVG Internet Security user interface and click the Privacy tile.
- Click Open above Sensitive Data Shield.
- Click Scan For Sensitive Documents.
- Sensitive Data Shield starts scanning your PC for sensitive documents. If you want to cancel the scan, click Stop Scan.
