Smart Scan finds Advanced issues
AVG AntiVirus Smart Scan finds Advanced issues but does not say what they are or how it intends to remove them. This leaves the user in the dark as to what AVG is trying to do to his computer system.
Hello Avner,
We're sorry to hear that you feel that way.
Please share us the screenshot of the "Advanced scan results" you're referring to, so that we can check & assist you further.
Thank you for understanding.
Unfortunately, your system does not make it possible to share a screenshot. When you click on the Image icon above an Insert Image dialog box appears but all its buttons are greyed out. There is no way to upload the screenshot. You cannot even close the dialog box to go back to the page you were on. I have tried two different browsers with the same results. BTW, the screenshot is of the AVG Smart Scan results, not of “Advanced scan results.”
Hello Avner,
