Hello Carol. I would like to inform you that AVG Program deactivator is a feature of AVG PC Tuneup(which you purchased already). It helps you to deactivated some programs on your computer which you does not require them running in the background. It helps your PC to run faster. Please open the program deactivator to check and disable the programs. Please contact us back should you need any further assistance. Thank you.
I keep getting this pop-up and have no idea what it means. "Speed Up System" with Program Deactivator. Then I am told to open the AVG Program Deactivator. Are they trying to sell me something or is there a problem with my computer. I am a senior citizen and these things are very frustrating to me when I don't know what to do. Can anyone help me?
