Andrew, I have escalated your query to our senior team.
Once we get the reply, we will assist you.
Thank you for your patience Andrew,
Currently, we do not support split-tunneling. You can set up the routing in Windows in case you don't want to use VPN:
Please Use command:
route -p add IP_SMTP IP_Gateway metric 1
In which IP_SMTP is the IP address of your SMTP-server and IP_Gateway is the IP address of your Gateway.
Regards,
Does avg vpn support split-tunneling? I want to decide what programmes use the vpn and what ones don't.
