Starter problem
Hi Aly,
It seems that your hard drive is failing down. The S.M.A.R.T. check verifies whether hard drive is functioning without errors or getting to it's end of life. I'd recommend you to backup all the data from the hard drive and replace it with new one.
Hi Freinds,
I can't open my PC before start give me this message ( 3rd Master  Hard Disk: S.M.A.R.T. Status Bad, Backup and Replace Press F! Resume.)   other message when opend tell me (Packup your hard driver…) after I donload AVG remove all viruse and open my websit with save but still have the first message (3rd Master…)
please some advice me …
Aly
Hi Aly,
