Taskbar Problems
I have been using the free version.  Where is the AVG PC tuneup located in that version?
Thank you for working on this.  I guess I'll have to live with problem.
I have been using AVG products for several years and have been very pleased with their performance until my AVG 2013 was upgraded to AVG 2015 with AVG Zen.  I noticed now that all of my icons in the taskbar have disappeared and the options to customize the taskbar are grayed out.  My operating system is Windows XP.  Is there a way to restore the functionality of showing icons on the taskbar?
Hello Cary,
Please be informed that AVG Antivirus Free http://www.avg.com/us-en/free-antivirus-download is the only product available with us as free product. AVG PC TuneUp is avaliable as trial and paid version. Once the trial period of AVG PC TuneUp it expires and you need to purchase the paid one to activate AVG PC TuneUp back in your pc.
Hello Cary,
Do you have the Service Pack 3 installed for your Windows XP?
Hello Cary,
If you have accidentally installed the trial version of AVG PC tuneup then you can uninstall it from the control panel and after that you won't get the trial notices from it.
Thank you for confirming it.
Have you tried restore changes option on the AVG PC tuneup to bring back the changes made by it to your PC?
