My AVG tells me it has found 1 problem, when I try to open the PC Health window to fix it it will not load and then it tells me that tuscanx.exe has a problem.
I have deleted the program and reloaded etc but it gets the same result.
Hello Kerin.
I am sorry to hear about that. Please visit http://www.avg.com/tools#tba2 and click on "AVG Remover" to download the remover tool and run it on your PC. It will ask you to select which product you would like to uninstall. Please select "AVG Performance" and follow the setup instructions to uninstall AVG and then re install it. Thank you.
