Uninstalling Problem
Hello Mordechai,
I would request you not to post multiple threads for same issue. You won't obtain an answer to your query any faster! Please refer your other posting via https://support.avg.com/answers?id=906b00000008sCT . Thank you.
Hello Support
After dowloading the removal tool, (hope it will work) and before I remain without any antivirus protection,
I downloaded two files :
1)AVG_Antivirus_Free_692.exe  = 2.856 KB
2)AVG_Antivirus_Free_x86_694.exe = 212.579 KB
Which one shall I use to install AVG antivirus free (only) offline.
My OS is Windows 7 pro - 32 bit.
Mordechai
Hello Support
Yes, I visited the link
Sorry again to write here, but I am despared!
Here is my problem: As recomended. I started to install AVG free antivirus with file
AVG_Antivirus_Free_x86_694.exe, after almost two hours, the installation was not finished - got
"Installation failed" notice, Error code 0xA0010004
I run the installation again with same results.
Description: Avent exec_finished
Now I have no Antivirus, and I am afraid to connect to internet for a long period, just to write
this answer.
Please help me to solve the problem and let me know what to do.
Cannot attach the log file - no place here where to attach a file.
Waiting for an answer please
Mordechai
