Have recently found that e mails are not coming through from my provider to Thunderbird, which I use to view/action mails.
I have found that if I disable in AVG Free the "Web Shield" & "E mail Shield" the messages then get delivered.
So have you made any changes in the areas I have stated?
Or what do I do to clear the problem?
Hi John,
We are sorry to hear this.
Could you mention the version of the AVG program?
Are you able send email without any issues?
Keep us posted.
We appreciate your efforts
Let us know, the status of the issue.
OK, done it, will let you know results.
The AVG program is Version:- 20.9.3152, Build 20.9.5758.617.
Virus data base:- 201209-0
Yes I am able to send e mails
In this case, we'd request to uninstall AVG using clear tool and install it again https://support.avg.com/SupportArticleView?l=en&urlName=Uninstall-AVG-software-Clear-Remover&supportType=home
Refer this article for installation https://support.avg.com/SupportArticleView?urlname=Install-AVG-AntiVirus-Free
