Wi-Fi adaptor problems
Hi Mary,
We are here to help.
AVG TuneUp wont interfere with the WIFI since it is a performance software. Did you made any recent changes using the AVG TuneUp?
Do you have any AntiVirus installed in your computer?
Keep us posted.
I am also having this problem also, the only thing that has happened in the last fortnight was I ran the tuneup program.  Never lost the WiFi for the previous 6 months, then it constantly drops out every day.
Ever since I purchased subscription and installed AVG TuneUp, I lose my Wi-Fi connection constantly.  I have to diagnose and get it fixed (Windows 10) several times a day! Should I uninstall AVG Tuneup because of this nuisance?
Hi Mary,
Keep us posted.
Hello David,
AVG Tuneup program will not block the access of Wi-Fi connection. If you think AVG Tuneup causing it, you can try to uninstall Tuneup (https://support.avg.com/SupportArticleView?urlname=Uninstall-AVG-TuneUp) and check the status.
Keep us updated.
