Hi Nelia,
Please try reinstall AVG according to this article.
I purchased a wifi router and had problems from the start when connecting to the internet. At first I thought it was my pc and even purchased 2015 ZEN. After some time and asking my daughter to check if her pc does the same, also researching the problem on the internet after starting to suspect it might be AVG, we saw that the same problem happens on her pc. I then uninstalled AVG and lo and behold, my internet connection problems using wifi, stopped. Then I wanted to reinstall AVG, but now it download, but doesn't install, I just get an error message. So AVG team, it seems as if this wifi problem exists since 2011. When are you going to fix it and how can I now reinstall it?
Hi Nelia,
