We will make sure to fix this issue for you.
Yes, the basic version of AVG does not include Firewall feature.
Follow the below steps to disable AVG temporarily on your computer and check if you are able to print.
To disable AVG temporarily, please right click on the AVG icon present at the bottom right corner of your desktop(System Tray) and you can see a scroll bar to "Disable Protection".
If you face any difficulties, please let us know and we will assist you further.
Jim, we have to make some configuration in your AVG firewall in order to get this issue resolved.
Please follow the below steps to configure the firewall:
Open AVG Internet Security -> Menu at the top right -> Settings -> Components -> firewall -> customize -> system rules -> make sure all the task has been enabled.
Again, Firewall -> Customize -> Network Profiles -> change all the profiles from public to Private.
Let us know the status of the issue.
I think my avg security "free" version is stopping my canon imageClass laser printer from sending the print job to the que, to the printer. All other wireless communications are properly set up.
It appears my free version only has "basic protection", I do not see the firewall, the screen shot below shows firewall only available in "full protection", I have the free version. Please let me know, thank you very much for your reply, this is a headache, spent great deal of time to finally determine it might be AVG software. Is there an alternative? Jim
Thank you for the information Jsk,
It seems AVG Antivirus Free is not blocking your Printer, since it's not working when AVG Antivirus Free is disabled. If you still think that the problem is AVG Antivirus Free, then please uninstall AVG Antivirus Free from control panel > program and features and check the status.
Regards,
I turned AVG off, I received the same message "word can't print due to problem with printer set up"
Any other ideas because the driver software has been downloaded and according to Canon tech everything checks out, it should work. I printed from Mopria from mobile phone, and the printer recognizes the lap top computer.
What about exceptions, don't know how to use it, but saw it in settings?
Thank you for your assistance.
Jim
